Broadband sensor
sedge
Broadband sensor
Post by sedge » Thu Feb 16, 2017 6:58 pm
Hi,does anyone know if a broadband o2 sensor gives any usable data when the engine is cranking over, also are the short term fuel trim readings of any use when the engine is cranking over ?.
Re: Broadband sensor
Post by STC » Thu Feb 16, 2017 7:46 pm
Sedge
Apologies for answering a Question with another Question.
Please elaborate. what issues are you facing. What Car, Model, Engine Code, Symptoms, Fault Codes etc. .... .... ..... ..... ..
As for gaining anything from any O2 sensor whilst Cranking -
1. They don't work until they are up to temperature
2. Most cars start up with a slight Rich Strategy, different from Idle / running strategy.
3. The ECU wont be listening to the O2's until it is in closed loop
sedge
Post by sedge » Fri Feb 17, 2017 4:37 pm
Cheers for the reply. Its something that i have never had the need to think about before. I had a none starter and it wasn't making any sense because it had everything it needed to start ie. compression, fuel, spark, etc etc.It was a petrol that had been wrong fueled with diesel, but it eventually fired in and now runs sweet.Thanks again.
Post by STC » Sat Feb 18, 2017 12:50 am
Hi Sedge
Thanks for the feedback.
