Volvo V50
RS-4
Volvo V50
Post by RS-4 » Sun Feb 05, 2017 1:36 pm
Hallo to all,
I need your help ... Problem is 2.0 Volvo V50 2009 (D4204T) engine will not start, which has an error P0087 - pressure too low. Signal from rail sensor has a lot of noise ... pump control (pwm) is ok... CR pump is new. The amount of fuel to the pump is ok. I measured fuel amount of the return pipes on injectors that's ok. I also need your opinion of the signal from the injector ...
pressure sensor + regulator on CR pump.psdata
(2.93 MiB) Downloaded 93 times
pressure sensor + injector cil.4.psdata
Pressure sensor to the voltage ok, enough? I think there is a lot of noise?
(3.8 MiB) Downloaded 114 times
dieseljohnny
Re: Volvo V50
Post by dieseljohnny » Sun Feb 05, 2017 7:20 pm
Can you do a relative compression and injector current trace?
Also I think cranking speed is a bit slow if Im working it out right at 150Rpm approximately from the injector current trace.
Im just wondering why its throwing/or thrown a pressure too low fault but it appears to be actuating the injectors, well one of them anyway.
Perhaps its happening at the wrong time or other problem?
Re: Volvo V50
Post by STC » Sun Feb 05, 2017 7:38 pm
It's not firing the injectors, measure the duration time, it is, at best, checking that they are there - Open / Short Circuit test ? Also explains the lack of Pilot Injection ?
It goes around twice and fires once, I see Cranking speed as circa 282 Rpm.
Looking at FRP, the Fault Code is bang on - Pressure is low.
dieseljohnny
Re: Volvo V50
Post by dieseljohnny » Sun Feb 05, 2017 8:17 pm
Makes perfect sense.
Sorry I posted without fully thinking through what I was looking at :oops:
With some filtering I can also see the effects of cranking on the rail pressure voltage.
Re: Volvo V50
Post by STC » Mon Feb 06, 2017 10:26 am
Johnny
I think we can all be a little hit & miss on a Sunday Evening :D :D :D
RS
From memory that is Dual Point Control. SCV on the pump and a Pressure Regulator on the rail. Is that right ?
What Pressure and flow rate do you have ?
Do you have something to measure HP Pump Output - Delphi Sealed Rail Kit, Bosch Set 3 ..... ?
You could unplug the SCV and power the RPR to 90% with a PWM emulator, that should force it to produce maximum pressure. IF you do get the pressure up - Be sure to relieve it before cranking it again, or it will cause a lot of damage
I wouldn't worry too much about the noise on FRP right now, things are noisy at cranking.
steevegt
Re: Volvo V50
Post by steevegt » Mon Feb 06, 2017 11:41 am
STC, it looks like to me that it is firing the injectors. Piezoelectric ones, right?
In the beginning of the capturing, it looks like you do have a pilot injection with a 1.5 ms main injection opening time:
Pilot and Main injection event
Am I seeing this wrong?
At the end of the capture, the injector opening time is almost 5 ms. I believe this is too much, as far as I can tell!? But I guess it makes sense, because the opening time, for the same amount of fuel, has to be indirectly proportional to the pressure in the rail, right?
Main injection event only
To clear the noise in the FRP sensor you could use the 1khz filter, like I did...
With that you can see on your first capture that the pressure looks like it is low, and very unstable also:
Low and unstable pressure
Re: Volvo V50
Post by STC » Mon Feb 06, 2017 4:29 pm
You have got me thinking twice now !!
First and foremost, with that DTC and Low Pressure they should not be firing. I would not be expecting them to.
I'm not so sure that the current draw to Open and Close the Stack is minimal - Possibly not enough to fire fuel.
RS-4
Re: Volvo V50
Post by RS-4 » Mon Feb 06, 2017 4:45 pm
Hallo,
Thank you very much for your answers. I know that the picture is clearer when filter's turn on but I think there is some problem and because of him are so many noises, perhaps I'm wrong.
I still fighting with the car ... Today I made a couple of shots ...crankshaft and camshaft signals are so bad the voltage drop is too large and the signals look bad. I checked the power and ground of ECU and that is ok. Maybe the problem is in the engine computer ... tomorrow I'll open it up to see what it looks like inside.
P.S. I also wonder why there is firing to the injectors when the rail pressure signal is bad...
I can to hook shots ... I do not know why
steevegt
Re: Volvo V50
Post by steevegt » Mon Feb 06, 2017 5:52 pm
STC wrote: ...
The waveform structure of a piezoelectric injector is there, including (sometimes) the pilot injection event.
The current and the time width of the command, does look "short", I agree... I guess we need a good waveform of this system to compare and be 100%.
It could just be the computer way of detecting shorts, opens, etc. on the circuit, like you said.
Curious it does that with a pilot injection event also...
RS-4 wrote: ...
If you want, try to use the sensor ground, as the scope ground. It should clear the signal...
You are using the battery ground right?
RS-4 wrote: ...
I don't understand very well what you are saying about volt drop, but I don't want to explore that also... :wink:
Post the files if you want. It's easier for someone to help that way.
How did you validate the power and ground of the ECU? Also validate the reference and ground of FRP sensor... That will be my next move, just to be sure. After that I would chase a bad pressure problem...
The injection timing events on the first files you send, they should rule, at least, the crank signal. The timing of them are very plausible...
RS-4 wrote: ...
As far as I'm concerned, the injectors being fired is not a fact. At most a possibility...
Re: Volvo V50
Post by STC » Mon Feb 06, 2017 7:45 pm
Here is a known good from that Engine, I don't have one at cranking, only at Idle speed
And that turns my theory on its head :? I think I got too tied up with "They Shouldn't be Firing" and "if they are firing it should start" Hopefully not a completely insane thought process ???
We could sniff the Upstream DPF sensor pipe for Hydrocarbons ? Or fit a variable potentiometer in place of the FRP and wind it up from 0.5v up to 1.5v whilst scoping FRP and Injectors and look for change as it sees pressure and crosses the threshold.
RS
The car is shouting out at you in the way of a DTC that FRP is low, a fatal fault that will quite likely paralyse it. I am confused as to why you are not chasing that first.
