Non starting GolfV BKC
victor2k
Post by victor2k » Sat Feb 04, 2017 4:22 pm
I have a non-starting GolfV /2005/BKC.
No faults stored in ECU memory.The engine not start with spray but cam vs crank is ok.
Cam vs crank ,compression and injectors curent vs voltage was checked.The quality of fuel wasn't checked.Also the supply pump wasn't checked.
Only at 360* crankshaft I see a strange peak(intake valves not open on all 4 cylinders ?).
Don't know why I have noise on pressure sensor ( sensor and scope was't protected by engine vibrations-this is what I think) when engine is cranking!
Please look at my recordings.Any advice is wellcome.
Thank you.
Volkswagen_Golf_2005_Diesel_20170204-0002.psdata
(1.7 MiB) Downloaded 147 times
Volkswagen_Golf_2005_Diesel_20170203-0001.psdata
(4.08 MiB) Downloaded 84 times
Volkswagen_Golf_2005_Diesel_20170204-0001.psdata
(1.75 MiB) Downloaded 85 times
grunf1976
Re: Non starting GolfV BKC
Post by grunf1976 » Sat Feb 04, 2017 7:00 pm
Hi Victor
Did the car shut down while driving or is it just a non start after sitting parked?
Also do you hear lift pump when you cycle the ignition? I found that stuck intake manifold flap can cause a non start on these.
As for the pressure sensor I dont think that it is a noise. Maybe a damaged lifter. Also common fault on these.
And another thing, check this out as for the cam and crank. Might be of some help.
https://www.picoauto.com/library/case-s ... cold-start
Mickey
victor2k
Post by victor2k » Mon Feb 06, 2017 12:36 pm
The lifting pump not work.
What adapter I must use to check tandem pump pressure?KTS give me 0 986 613 102 special tool code for check this.
Thank you
grunf1976
Post by grunf1976 » Mon Feb 06, 2017 5:55 pm
I dont know Bosch tool code but I have original one. It is just a banjo bolt modified a little bit.
Post by STC » Mon Feb 06, 2017 8:53 pm
http://www.ebay.co.uk/itm/AN-6-6AN-AN06 ... Sw-KFXckj7
That is all you need.
If it won't start with spray then that points to a Mechanical, Compression, Intake or Exhaust airflow issue ???
Starting (or attempting to) on spray should take care of that, more so if you cut / block the supply from the tank or filter
dieseljohnny
Post by dieseljohnny » Wed Feb 08, 2017 9:11 pm
Have you checked the Turbo?
Common for them to block compressor housing or turbine housing as are forced out causing no start or start and stall.
One other thing is the Injector voltage only peaks around 5.5v in your waveform?
I only have injector Voltage and current from running but is generally within a volt of battery voltage at the time
Control unit supply problem or was the battery low on these captures?
As for the compression waveform can a comparison vehicle be got?
