need good cam crank trace for mazda 2.2 diesel
ross0530
Post by ross0530 » Fri Jan 20, 2017 9:21 am
I have a trace here but believe it to be a bad one does anyone have a known good one they can share
Ben Martins
Re: need good cam crank trace for mazda 2.2 diesel
Post by Ben Martins » Mon May 15, 2017 11:08 am
Probably a bit late in the day to be responding to this! But always check the waveform library. Have found a trace uploaded for cam and crank which you can use to compare to your capture. Not sure if much help now but maybe in the future!
