CanBus on Transit Custom
Re: CanBus on Transit Custom
Post by Fat Freddy » Sat Apr 22, 2017 11:45 am
Hi Richard.
I must apologize. 'Good' is probably not the right wording. A lot better is a more suiting term. I hadn't applied the Maths for the download.
I agree. I would have considered it unusable also and was surprised it was still a valid bus with the right software/hardware.
And no I don't have a after capture after repair but here is a capture with the PCM disconnected. Still not perfect but IIRC other scan tools could then communicate.
Post by FioranoCars » Sat Apr 22, 2017 11:52 am
Thanks FF
That's great, just wanted to see if it was a 2.5v base with something in the Engine ECU chipset pulling up the voltage to the weird levels, or if this was some other "new" operational voltage level ... clearly it should be 2.5v, which is re-assuring!
Hope the weather is good out there, we might be getting snow this weekend over here :-(
Cheers
Post by STC » Sat Apr 22, 2017 9:49 pm
There is no stipulation for Can Voltage - It can be anything.
Mercedes Benz Body CAN is recessive (asleep) at circa 8v.
When examining the system for parasitic drains, measuring 8v on that network is a PASS. Move on ...
The variables are numerous - endless ...
It is a case of Specialising in a brand or 2, either that or be a busy fool - like me - always playing catch up.
lukascz
Post by lukascz » Tue Jan 15, 2019 10:52 am
Hello, I have the same problem with Ford Custom. Can-bus data are sporadically wrong. What was your cause of the problem?
Best regards.
