Citroen Relay 2.2 2013 Need good cam crank trace
Dcunning35
Re: Citroen Relay 2.2 2013 Need good cam crank trace
Post by Dcunning35 »
If you pm me il give my number I may be able to explain better.
Danny
Darren Cotton
Post by Darren Cotton »
BK13XMS Relay 2.2 cam v crank 2 page.psdata
(3.16 MiB) Downloaded 927 times
Kevhutton
Post by Kevhutton »
Good morning, did this problem get resolved?
I have exactly the same issue with my 2013 Relay, P0016 appears as soon as the engine is started but the engine runs fine. I've had a new cam chain fitted and the timing rechecked, new crankshaft sensor, new camshaft sensor, tested the wiring to the ECU from each sensor. The van runs fine for a few thousand miles until the DPF dosing pump fails then goes into limp mode with the check engine light on. If I replace the DPF pump it runs fine again. After every 5mins of driving it does a DPF clean until the dosing pump fails (I'm assuming that this is linked to the can/crank synchronization problem on P0016).
Any help would be appreciated....
Arek
Post by Arek »
Hello, do you solve the problem? I have the same.
Post by Martyn »
If you look at the dates of the posts they are old so you are unlikely to get a response, as the poelp may no longer be acitve on the forums. I would suggest you post your issue, and what information you have gathered to date in a new topic to see if anyone can assist.
