NVH - rpm input pre obd car
LarsT
Post by LarsT » Tue Jan 03, 2017 11:20 pm
Just got the NVH system and am trying it out on a car without a data link connector- 1992 300TE Mercedes. Will any rpm signal work? - I have two choices on the 9 pin diagnostic connector under the hood, Pin 1 rpm signal 0-12volts, 4 pulses per revolution or pins 7 and 8 are from the crank sensor, I think it is just a raw crank sensor.
Thanks, Lars
Re: NVH - rpm input pre obd car
Post by Steve Smith » Wed Jan 04, 2017 10:40 am
Hello Lars and thank you for the post.
Either of these pins will do, you will just need to select the number of pulses per revolution.
The image below will help.
NVH RPM Input-Channel D
Channel D will now be utilised to provide the engine speed signal to the NVH software.
LarsT
Post by LarsT » Wed Jan 04, 2017 1:27 pm
Thanks! I don't think I read past "square wave".....Makes sense now, thanks again!
Lars
