timing chain issue?
MD tech
Re: timing chain issue?
Post by MD tech » Thu Nov 24, 2016 12:52 pm
Autonerdz wrote:Nothing shifted. The scope just triggered on that ignition spike in frame 5.
Thanks for pointing that out, I had been running it with a filter, I ran the test again with a longer time base and the patterns are not moving in relation to each other, guess I have to keep looking.
Post by STC » Thu Nov 24, 2016 1:17 pm
Bear in mind that does not mean that the Crank & Cam are not misaligned, now it will have to be a case of getting a Known Good capture to compare. WPS in a Cylinder may show the error.
A vacuum guage on the inlet could help too.
