New beta v16.12.4.2427 bug zooming
Post by FioranoCars » Fri Nov 18, 2016 10:51 am
Using the 3243 scope
PC is Win10 x64 lots (ASUS) lots of memory/fast processor etc (Steve you have the spec from another support ticket)
It was the second capture of the session (PC not rebooted, but software started)
Once problem occurred swapped to normal release version and continued without further incident, sadly due to time pressure could not take screen shots .... sorry
The lines are redrawn in THICK widths when redrawn, so it was impossible to see the crank waveform at all, no matter how deep the zoom, just solid!
Could not open the file in RC version, as it's not backward readable.
So the capture was taken (using a trigger), same bug as already reported! :!: so beta not fixed that!
Once complete, the capture was zoomed, moved within zoom, backup of zoom, rezoom etc etc (some possibly before save, and might have had the issue before save, and might not have checked zoom after save), it might have been there from the first zoom attempt, or might have become thick lines after a few zooms, sorry was up against a time constraint!
Anyway this morning re-opened in the Beta software (it had been closed and restarted since yesterday) although PC has not been rebooted or even slept, and the file views fine, zoom is good, can see all the detail.
Sorry, it's not much to go on, but maybe now the "bug" is in the awareness others might be able to tied down their actions leading up to it's appearance more carefully than I did!
355 flywheel 02.psdata
Datafile with zoom issue
(2.08 MiB) Downloaded 137 times
Re: New beta v16.12.4.2427 bug zooming
Post by FioranoCars » Wed Nov 23, 2016 10:09 am
Bug update
Finally managed to get this to recur
1. Latest beta still (beta v16.12.4.2427) on fast W10x64 lots of ram PC (Steve has PC spec) but using a NVidia GeForce GTX960M touch/pen not enabled.
2. Triggered capture (same template as previous upload, maybe extra channel in use)
3. zoomed before saving, post saving made no difference.
4. First Zoom gave thick lines, I think the video file captures 3rd and 4th zoom, so was already zoomed, hence why started the video recorder. I think initial screen draw was fine, but not 100% as was zooming straight away to see detail.
5. Save file, close Pico, restart beta, load from recent files, all OK with Zoom.
6. Scope was a 3423
Not sure if the Bug reproduces if you save first BEFORE zooming, but will try that too.
Bug does not happen each capture, only once in 4-8 yesterday
bandicam 2016-11-22 12-37-27-791.mp4
video of zooming and thickj lines
(1.07 MiB) Downloaded 165 times
volrem
Post by volrem » Wed Nov 23, 2016 10:38 am
I have noticed that for a year. Maybe more maybe less.
Doesn't happen often.
Post by FioranoCars » Wed Nov 23, 2016 11:09 am
I've not noticed it before with either beta or RC software, on 3 or 4 series scopes, but then again might not have been paying any attention :oops:
The laptop this happens on has been in service for 6months, so not new to Pico duty!
Not seen it on any other Laptop ... yet
Post by Steve Smith » Mon Nov 28, 2016 7:24 am
Thank you Richard and Volrem for the posts and for persisting with the reproduction of the symptom.
I will create a bug report and file this ASAP.
Take care.......Steve
Post by Steve Smith » Tue Nov 29, 2016 3:17 pm
Hello again, the bug is filed and now with the software team
Thank you again, take care......Steve
