Signal noise on cam sesors BMW E87
Postby bonecrusher » Thu Oct 20, 2016 11:18 am
Hello Guys
I am working on this BMW e87 with N46 engine I have signal distortion on the cam patterns , what causes this?
bonecrusher
Re: Signal noise on cam sesors BMW E87
Postby STC » Thu Oct 20, 2016 2:36 pm
Is this a Petrol 4 cylinder Direct Injection ??
I'm guessing its the Coils Multi Striking and wondering where your scope leads are routed.
That distortion is possibly nothing to worry about. The ECU will either not see it or ignore it.
Could you post the File Please, better still take another capture with Crank, Ignition Primary Cylinder 1 and Injector 1 at idle and post that. (Cold Engine)
What are the Symptoms / Fault Codes ?
Postby FioranoCars » Fri Oct 21, 2016 2:32 pm
STC wrote:That distortion is possibly nothing to worry about. The ECU will either not see it or ignore it.
I agreee, but it could be the spacing of the sensor is at the max, check the spec for spacing and face of the sensor for damage/debriss ... or it could indicate an out of true phonic wheel, or at least a slightly bent one ... Even float on the shaft (crank) as it moves. But not enough to cause concern right now, unless it's getting worse, then might be good to know which it is. Adding a voltage reading (at the sensor) might shed some light, as might earth if there is an earth problem (highly unlikely though).
Saw this, much worse definition - ie massive dips, on an Alfa that had been put back together by complete idiots, and the phonic wheel was bent, sadly the phonic wheel was the least of the problems, the engine was a box of spanners. Owner said he'd driven it the day before just fine ... yes, absolutely sir!! Dumb A55!
Be nice to know what you find for the sensor, and why you were looking at it.
Best to post the capture files for anything you want looked at so we can see the raw data.
STC wrote:What are the Symptoms / Fault Codes ?
Ditto
Good luck
Postby STC » Fri Oct 21, 2016 5:03 pm
Looking at the rise and fall of Crank sensor amplitude, the interference appears to line up with where I would guess injection/spark events could be. This is Direct Injection, right ?
Add to that the events occur 4 times per 720 of the crank or 360 of each cam and evenly spaced.
Hence I asked for the additional traces. Cold Engine as that is where multistrike will occur.
Postby bonecrusher » Tue Oct 25, 2016 9:07 am
Hello Guys
Thanks for all the feedback. I am still new to the pico. Although I have it for a while now. I only used 5 times maximum. Back to the topic discussion. I used sensor ground connected to the PICO and all noise/interference is solved.
bonecrusher
Postby FioranoCars » Tue Oct 25, 2016 10:49 am
Hi, and thanks for posting back an update
Was there a reason for the test, or just curiosity and having a play with Pico (ie was there a fault on the car)?
Do you have a saved Good waveform? Maybe you can upload it to the Pico waveform library, with a note about the noise when taking the ground from elsewhere?
Postby STC » Tue Oct 25, 2016 8:58 pm
You don't make it clear where you had the scope Earth on the original capture, even more bewildered with what "Sensor Earth" is ? Have you gone from Battery to the Earth on the 3 Sensors ??
I know that DLC Pin 4 is "Chassis Ground" Pin 5 is "Sensor Ground" but that is a nonsense with most cars as they are wired together and always to an Earth Point on the Chassis / Body
I still think that interference is real, moving the earth has only masked it, I still maintain it is unlikely to affect the car. A quick calculation suggests that it is running at ~ 1000rpm
The interference is too regular, 5 spikes each time and always as a piston is at / near TDC from my reckoning.
Postby FioranoCars » Tue Oct 25, 2016 9:13 pm
Subject: Signal noise on cam sesors BMW E87
Hi George
Ok, I am guessing BoneCrusher is referring, just as I would ( :oops: !!), to, for instance on a hall effect sensor sensor of typically 3 wires ...
1. supply (+12v)
2. ground (chassis)
3. Signal (often shielded)
So maybe he's saying he probed the ground wire on the connector at the sensor, second time round, verse the initial test where some chassis or worse some engine part was used!
Of course normally the engine ECU is supplying (or some near chassis point to the ECU) the ground, and if using the engine direct for the scope earth there will be a lot more noise (and possible volt drop over the earth strap(s) to the chassis).
The new 4 series floating earth's have great benefits, but also can cause confussion too...
Sorry to semi-answer for you BoneCrusher, I'm not really, honest!
Please do tell what happened, it's so we can all learn. And why you where checking it?
Postby STC » Tue Oct 25, 2016 10:13 pm
x2
