Volvo v70 misfire
bullstar
Volvo v70 misfire
Post by bullstar » Sat Oct 15, 2016 5:58 pm
Hi, Just bought a wps so thought I would try it on a misfiring Volvo 1999 model 10 valve, following the software instructions I did a compression test, the figures on all 5 cyls were identical around 167 psi but I'm not sure what the small peaks are , is this a valve reading?
with a vacuum gauge I'm reading 13 inHG steady, valve timing ?
done vacuum test also with wps , used zoom, see pics
volvo v70 cyl relative compression.psdata
(469.5 KiB) Downloaded 106 times
volvo v70 intake vacuum test.psdata
(924.97 KiB) Downloaded 95 times
volvo v70 zoom range 3.psdata
(348.7 KiB) Downloaded 86 times
volvo v70 cyl 1 compression test.psdata
(199.15 KiB) Downloaded 98 times
volrem
Re: Volvo v70 misfire
Post by volrem » Sun Oct 16, 2016 11:24 am
I would say that this small peak (0,8 bar) is because exhaust valve closes too early.
bullstar
Post by bullstar » Sun Oct 16, 2016 2:44 pm
Thanks for your input, I was thinking it was the exhaust stoke as if I put the rulers up in degrees from compression peak to peak 720 degrees the 0.8 bar is in exhaust stroke, Surely There should be no peak on a compression test
andrewbishop66
Post by andrewbishop66 » Sun Oct 16, 2016 5:03 pm
how about cylinder leak back test the peak could be due to leaking valves on its companion cylinder causing the pressure increase
Thanks andrew
andrewbishop66
Post by andrewbishop66 » Sun Oct 16, 2016 5:38 pm
dont know if this helps
bullstar
Post by bullstar » Wed Oct 19, 2016 7:37 am
Hi, thanks for your input , yes a cylinder leakage is the next test we going to do on this car , I believe the car is similar to the test results as the valve train also sounds a little noisy and could be the symptoms of valve lash.
volrem
Post by volrem » Wed Oct 19, 2016 7:40 am
Measure cam and crank to see if timing is off.
victor2k
Post by victor2k » Wed Oct 19, 2016 9:14 am
Or check the cylinder pressure waveforms for all cylinders to see the wear of exhaust camshaft.
