Advice regarding scope wave forms
scopeman
Post by scopeman »
Hi all,
New user here ..just got a pico scope 2 channel older model..was trying it out on cam sensor and ignition coil .I have uploaded 2 images ..Cam sensor seems a bit wavy in places ,is this the scope itself causing this ? only i have used a cheap scope in the past and it did not look like this ?
Car runs fine ,no issues.Also any ideas as to why current waveform has that point in the middle of the wave form for coil.
Thanks in advance.
Vauxhall_Astra_20160809-0001.psdata
(666.46 KiB) Downloaded 547 times
Vauxhall_Astra_2003_Petrol_20160809-0004.psdata
(3.22 MiB) Downloaded 528 times
PicoPhil
Re: Advice regarding scope wave forms
Post by PicoPhil »
Hi and welcome to the forum group.
I look at lots of waveforms and these both look strange. Can you give me the vehicle details. Make . Model. Engine size, Engine code. fuel type, so i may investigate. Have you looked at the waveform library to compare. We have a youtube video on saving a waveform and how to use the library. Most of the team are away form the office in Frankfurt doing Automechanika next week so there may be a delay in replying to you.
Phil R
Although it has been superseded, the 3223 is still more than capable of measuring cam & coil signals - and some.
Those captures are strange indeed, although if they were an accurate reflection / measurement and those weird bits were in the car it could still run well. Possibly a bad earth or interference ? Genuine scope leads ?
The downside of the 3223 is that you can damage a channel if you forget to use an attenuator. Have you tried it on another car ? How about trying Channel B.
If it is faulty talk to Pico, they don't make a big deal of repairing it neither do they demand an arm and a leg.
