Nissan Micra 1.2 2008 running rough, worse from cold
wilkwhit
Post by wilkwhit » Tue Aug 09, 2016 9:18 am
Hi, we have a 2008 Nissan Micra 1.2 that I suspect the timing may have jumped but have compared it to various wave forms and I can't decide if it's good or bad?
John
Nissan_Micra_2008_Petrol_20160809-0001GRAVEMICRASAVED.psdata
(3.92 MiB) Downloaded 301 times
Re: Nissan Micra 1.2 2008 running rough, worse from cold
Post by STC » Tue Aug 09, 2016 5:06 pm
I don't have anything to compare your waveform to just now, but I notice that both your CKP and CMP are Minus -2 & and -3 volts. I stand to be corrected but that looks wrong to me ? Especially the CMP where the base line drifts by 500mv+
Where have you earthed the Scope ?
Would this not throw a P0341 if timing was adrift ?? The older ones ~2002 / 2003 certainly did.
As for timing, can you get a vacuum reading with a gauge T'eed in ?
hvac
Post by hvac » Wed Aug 10, 2016 8:34 am
If you compare to this image it seems your timing is off.
