EGR voltage multimeter
the57
Post by the57 » Sat Aug 06, 2016 3:37 pm
I have a 2007 ford focus 1.6tdci with a P042f code:- Exhaust gas recirculation (EGR) valve actuator A – actuator stuck closed, I've replaced with a new EGR and still the same code, so with a multimeter i checked the the wiring, i got:
pin 1- 5v ref
pin 2- 2.6 i think is signal
pin 3- 0.14
pin 4- 0.48
pin 5- 0.01 ground
should i have 12v on one of pin 3 or 4 or is it power side switched. Thanks
Re: EGR voltage multimeter
Post by STC » Tue Aug 09, 2016 9:09 pm
Taking Voltmeter readings at one end is a great start but by no means is it "Checking Wiring"
For that you will need access to an accurate wiring diagram so it can all begin to make sense. And of course it would be a good idea to look at feedback whilst it is being activated and moving from stop to stop.
Post by STC » Tue Aug 09, 2016 9:10 pm
victor2k
Post by victor2k » Wed Aug 10, 2016 5:12 am
About P042F fault code I have some bad news...replacing EGR and adapting the new one in ECU will not solve the issue,but replacing ECU(in my case) yes.
I think you must scope the feedback signal from EGR vs actuation(curent or voltage)
Dcunning35
Post by Dcunning35 » Fri Aug 12, 2016 9:48 pm
Hi if you give me reg via pm Il email you factory diagram , this dtc is usually a pcm fault with motor circuit pal but send me over reg or vin and Il give you all help I can .
Danny
Dcunning35
Post by Dcunning35 » Fri Aug 12, 2016 9:49 pm
The status and failiure modes of dtc will help too
Danny
the57
Post by the57 » Sat Aug 13, 2016 8:16 pm
Same at pcm, dead driver i think, i should have 12v, will a different 12v feed work.
the57
Post by the57 » Mon Aug 15, 2016 8:22 pm
There is 12v at pin 3 for a few seconds and then it drop to 0v, should i have 12v at pin 2
the57
Post by the57 » Mon Aug 15, 2016 8:37 pm
Dcunning35 wrote:Hi if you give me reg via pm Il email you factory diagram , this dtc is usually a pcm fault with motor circuit pal but send me over reg or vin and Il give you all help I can .
Danny
Danny the pm not working
Dcunning35
Post by Dcunning35 » Wed Aug 17, 2016 8:26 pm
Sent you a pm 57 just reply with detail and Il see what I can do pal .
