ADC212
soptea
ADC212
Post by soptea » Wed Aug 03, 2016 9:49 am
Hi ,
I see that are 3 versions of ADC212 : 3 ,50 and 100 .Are they all compatible with automotive software ?
Thanks !
Re: ADC212
Post by Martyn » Wed Aug 03, 2016 10:11 am
The ADC212 is a very old product, we would not recommend purchasing one of these second hand.
It will only work on old 32 bit machine with a dedicated parallel port.
soptea
Re: ADC212
Post by soptea » Wed Aug 03, 2016 11:10 am
I Don t mine If it is old ,have 7 other scopes including a 500 msamples
one ,just want to test auto motive version as cheap as possible .Then start selling scopes to get a real auto motive scope .
Re: ADC212
Post by Martyn » Thu Aug 04, 2016 7:26 am
The ADC212's will run with the latest stable version of PicoScope 6 Automotive, but they are not guaranteed to run with future releases of the software.
They will not run Pico Diagnostics, and they will not run with 64 bit PC's
Therefore option with the ADC-212 is limited to using it with a 32 bit PC supporting a parallel connection, and running the current stable release of PicoScope 6. The parallel to USB converter we used to supply is obsolete and we have never found an alternative that works.
