cheaping it out on 20:1 attenuator or secondary ign pickup?
hillp
Post by hillp » Wed Feb 23, 2005 8:41 pm
Isn't the 20:1 attenuator simply a voltage divider, that I suspect I could build with resistors for just a few bucks? And how about the secondary ignition pickup? Could I just use the spark plug cable clamp used to measure rpm on my automotive multimeter?
Accessories
Post by Autonerdz » Thu Feb 24, 2005 5:03 pm
I'm not sure what it would take to make a 20:1 Attenuator, but I do know the ones Pico have work really well. They are accurate and distortion free.
As for the secondary pickups, these are capacitive 10,000/1 attenuated leads that produce a really nice response. An RPM pickup for your DVOM is an inductive clamp and would not show you the same thing at all. Very useful though for syncing a parade pattern using the external trigger 8)
