NVH RPM signal
NVH RPM signal
Postby no1lugnut » Sat Jun 18, 2016 5:41 pm
What is a MDI approved scan tool? My Snap on Modis Ultra does not work for the needed RPM signal for the NVH wizard. Nor does my CarDaq-M from Drew Technologies. Are there more detailed hook up instructions?
no1lugnut
Re: NVH RPM signal
Postby Mark Dalton » Fri Jun 24, 2016 8:28 am
A decent ELM327 interface from eBay will do the trick and they're pretty cheap. One with a USB Lead is probably the best option. I've done it with my Bluetooth one, but it was a bit unpredictable as to whether The Pico Software picked it up.
Mark Dalton
Re: NVH RPM signal
Postby Alexander » Mon Jun 27, 2016 10:32 am
no1lugnut wrote:What is a MDI approved scan tool? My Snap on Modis Ultra does not work for the needed RPM signal for the NVH wizard. Nor does my CarDaq-M from Drew Technologies. Are there more detailed hook up instructions?
Hi, sounds like you have the GM NVH software. Pico customises the NVH software for oem's and because GM dealerships have access to MDI scan tools this is primarily what the GM software supports. If you don't have one of these devices the software should work with any other J2534 compliant device.
Alexander
Return to PicoDiagnostics NVH
