renault master 2011 2.3cdi egr issues
jey001
Re: renault master 2011 2.3cdi egr issues
Post by jey001 » Tue Sep 06, 2016 9:21 pm
Are you able to pressurise it with a smoke machine up to 3 bar. Or better still a 95% Nitrogen / 5% Hydrogen Mix then use a Hydrogen sniffer ? Hydrogen being the slimmest on the periodic table ?
Of course not :lol:
As I told you, I'm not a mechanic, I just know the basics...
But still doing my best... And of course I want to solve that myself if possible...
Learning is always a pleasure :D
Post by STC » Tue Sep 06, 2016 10:16 pm
Sorry to say but quite clearly you don't know the basics,
duplicate post in error
jey001
Post by jey001 » Wed Sep 07, 2016 7:25 am
STC, I have not said I was a mechanic, ask me to change a head gasket, I will. Maybe the work will be longer than you, but it will be done and done well, is it a shame?
But I do not want to undertake this work if it is not the solution to my problem. So I will follow the advice of Dcunning35.
yes I know the basics of mechanics, except that the older engines were much easier to diagnose than new engines , filled with electronics, EGR, EGR Radiators, additional Electric water pumps, Particle filters, Electronic sensors in every corner...
If I asked too many questions, sorry ...
I am a car lover, and when I have a problem, I like to solve myself.
When I come on a forum, it's to get help, and when I can help someone, I do. The forums are not made for that?
I repeatedly thanked Dcunning35, for assistance, for the hug, it will require that we meet through the Internet it will be complicated :mrgreen:
I totally respect people like Dcunning35 who help others !
Should I be ashamed to come here and ask for advice from someone who has more experience in this?
But here we leave the subject I think?
Finally, STC, I do not understand what is your problem with me?
T*tS at home, Tyres, Training. Tooling & Techniques at work - Makes for great life at home and at work, Just my experience.
Not bad ;-)
Have a good day.
jey001
Post by jey001 » Mon Sep 12, 2016 1:40 pm
Hi Everybody !
Some pictures...
We had no access to the pipes to make a bypass...
So, we had to remove the front of the Truck.
(The cooler in place was not the good one, not the same that we have bought to Renault trucks, I suppose someone has already changed it before but not with the good model. One Pipe was on the back, and the cooling system was modified !!!)
After removing the EGR cooler, some water went out the admission circuit !!
The problem is well a cracked cooler. :D
We have mount a new cooler, now, have just ordered a new pipe for this cooler, because mine broke when we removed it
Same time, with easy access to everything, we are doing a big maintenance.
I will come to tell you when all will be fixed.
Thanks again for the help !
Work In Progress
Work In Progress
Dcunning35
Post by Dcunning35 » Mon Sep 12, 2016 2:00 pm
Blimey fella , you certainly stripped it to change the cooler anyway good luck to you .
Danny
jey001
Post by jey001 » Mon Sep 12, 2016 2:04 pm
Dcunning35 wrote:Blimey fella , you certainly stripped it to change the cooler anyway good luck to you .
Danny
yes , no choice , access is quite difficult ... ;-)
Thanks !
