Postby asmodai66 » Tue Apr 19, 2016 1:31 pm
Hi my name is Bora, I run my own garage we specialise in german vehicles.
I have an issue with a BMW E60 530d which I am trying to test the DDE-CAS wake up line. Does anyone know how to setup for the square wave pattern I need to see for this?
Many thanks
Bora
asmodai66
Re: Hi
Postby STC » Tue Apr 19, 2016 10:03 pm
Do you know what communication protocol that line uses ? Are you using a Picoscope ?
Have you tried leaving it set to "AUTO"
Re: Hi
Postby EAAD » Wed Apr 20, 2016 12:50 am
There is not enough information in the question imho? What's the "issue"?
CAS is attached to the bus on the e60 via K-CAN
There are 2 power options on this system...... Basic & Advanced Power Management options & will test different but may have the same signal?
As STC suggests, Pico auto settings will give you a base line to start and then open it up via both axis? If needed? But I cannot identify the connection, BMWTIS.com may give you workshop data further to my knowledge and may contain the information required?
EAAD
Return to Introductions
Users browsing this forum: No registered users and 3 guests
