esta analise e do eletroinjetor de um gm montana motor 1.8 f
xandro
Post by xandro »
:lol:
Re: esta analise e do eletroinjetor de um gm montana motor 1
Do you have the other image? Both appear to be the same. :(
HTH
Post by Martyn »
I believe this was in error, the second image has been removed.
busjockey
Post by busjockey »
It looks like by your scaling that it is at 10 volts per division and the Injector bat supply is at 14-15 Volts and the ground is at 8-900 millivolts, However I don't know how you have your amp clamp set up. How many millivolts per amp is is on your clamp? Also I'm sorry but I don't understand your language and I don't have a translator. I need to understand your question first before going any farther. :)
:lol:
Google translates this as
can see that this gun (gun being injector ??) does not have open issues and injector needle closure but already I will post a picture of the same car but with gun with locked needle and opening not enough to feed the cylinder, have current inductive kick is that the current circulates in enrrolamento is not being enough to move the needle and act correctly, this vehicle was running with bad fuel smell at the exhaust and as here in Brazil we use ethanol and issuportavel smell.
xandro wrote:
:lol:
