esta analise e do eletroinjetor de um gm montana motor 1.8 f
xandro
Post by xandro » Tue Mar 29, 2016 10:30 pm
:lol:
Re: esta analise e do eletroinjetor de um gm montana motor 1
Post by Fat Freddy » Wed Mar 30, 2016 10:16 am
Do you have the other image? Both appear to be the same. :(
HTH
Post by Martyn » Wed Mar 30, 2016 10:59 am
I believe this was in error, the second image has been removed.
busjockey
Post by busjockey » Wed Mar 30, 2016 3:34 pm
It looks like by your scaling that it is at 10 volts per division and the Injector bat supply is at 14-15 Volts and the ground is at 8-900 millivolts, However I don't know how you have your amp clamp set up. How many millivolts per amp is is on your clamp? Also I'm sorry but I don't understand your language and I don't have a translator. I need to understand your question first before going any farther. :)
Post by STC » Wed Mar 30, 2016 8:38 pm
xandro wrote:
:lol:
Google translates this as
can see that this gun (gun being injector ??) does not have open issues and injector needle closure but already I will post a picture of the same car but with gun with locked needle and opening not enough to feed the cylinder, have current inductive kick is that the current circulates in enrrolamento is not being enough to move the needle and act correctly, this vehicle was running with bad fuel smell at the exhaust and as here in Brazil we use ethanol and issuportavel smell.
xandro
Post by xandro » Thu Mar 31, 2016 2:30 am
Fat Freddy wrote:Hi
HTH
eu tenho sim amigo porem nao consegui postar a imagem para que todos pudessem dar opnioes, mas vou tentar fazer agora ok
xandro
Post by xandro » Thu Mar 31, 2016 2:39 am
:roll:
xandro
Post by xandro » Thu Mar 31, 2016 2:45 am
:D :D :D :D
Post by Fat Freddy » Thu Mar 31, 2016 3:48 am
Probably best starting another topic. But can't tell much from that image. Unfortunately shows the beauty of Pico. What makes you think the image shows a problem.
HTH
evolini tommy
Presentazione di Tommy Evolini
Post by evolini tommy » Mon Apr 04, 2016 1:15 pm
Ciaoo a tutti...Mi chiamo Tommy Evolini sono di Milano ed ultimamente ho acquistato il pico 4424 kit avanzato,nhw 4 assi,wps500,è dal 95 che utilizzo l'oscilloscopio,sono partito con un vecchio bosch a tubo catodico analogico,successivamente negli anni ho acquistato il 4 canali di Bosch 450 e il Motor tester 720 Sempre di Bosch che sono molto performanti sopratutto quando si analizza l'accensione secondaria,possiedo anche l'uniprobe di texa come generatore di segnali,ma le capacità della strumentazione di pico sono ineguagliabili,molto semplice,intuitivo ma estremamente efficace nelle acquisizioni!!!
Spero di migliorare sempre di più per imparare a sfruttare tutte le funzioni infinite presenti nel Software di pico!!
