esta analise e do eletroinjetor de um gm montana motor 1.8 f
busjockey
Re: esta analise e do eletroinjetor de um gm montana motor 1
Post by busjockey » Mon Apr 04, 2016 7:12 pm
Can you scope all the Injectors with a current clamp and then use voltage for power and ground as your synch that way we can compare? That would help us identify a problem with the injectors. Have you done a relative compression test?
