Polo 6N 1998 1,4 AKV-Engine Low Compression
terbo
Post by terbo »
Our VW Polo decided to run like crap from one day to the next.
Relative Compression did not look good.
Did a compression check with the WPS500 - doesn´t look good.
Tryed to test with the WPS500 at the Dipstick and Intake but could
not get any fitting that would seal.
Did a self made Leakdown test and i have some pressure at the Breather
Hose from the Crankcase :(
Is there anything else beside the Piston or Ring that could be the cause ?
The little dip after the Compression Peak is missing on Cylinder 2.
Does that support the Crankcase as cause ??
Maybe someone has a opion before i replace the Engine.
Car has about 100 000 km on the odo if it matters.
Greets Chris
z1-1.psdata
Cylinder 1
(95.61 KiB) Downloaded 726 times
z2-1.psdata
Cylinder 2 - BAD
(80.17 KiB) Downloaded 704 times
z3-1.psdata
Cylinder 3
(95.91 KiB) Downloaded 574 times
z4-1.psdata
Cylinder 4
(97.21 KiB) Downloaded 617 times
rel2-polo.psdata
(613.36 KiB) Downloaded 699 times
Re: Polo 6N 1998 1,4 AKV-Engine Low Compression
Generally speaking, 100k km is not enough to kill this / any engine. May we make replacing the Engine a last resort ?
Autodata suggests that the Spec for compression is 7 - 15 bar (very helpful) Indeed we all know all 4 should be even.
Your compression leak has to be going Up, Down or Sideways.
First the compression test must be done with the throttle plate wide open, or removed from the car. Did you do that?
Next consider doing Dry & Wet Compression tests (adding a little oil into each cylinder prior to testing)
Don't underestimate the value of "Running Compressions" on Each Cylinder.
Oil Loss ??
Water Loss ??
Smoke at Tailpipe ?? What Colour ?? What does it smell of ?
Liteace
Post by Liteace »
STC wrote:Generally speaking, 100k km is not enough to kill this / any engine
It is if it's not been looked after properly, oil changes, quality of oil used, it might have had the nuts thrashed out of it for 25k with crap oil in
Liteace.
With Opening Poster "Terbo" being a Seasoned Pico Owner / User. For that reason, I did omit to state the obvious basic stuff but offered further testing suggestions. Generally Speaking :D
My Apologies
I think Liteace is on the money.
And it is possibly repairable. Compression isn't too bad. But low.
Yes.
Running comp as suggested would be good.
HTH
terbo
Post by terbo »
After a talk with my Sister who drives it mostly,
she said, it started at highspeed on the freeway, there was
a "hard jerk" and big POPP and then it through big smoke clouds
and started runing von 3 cylinders.
She had to put in about 1,5 Liter Oil between the happening and
the house (rest way was about 200km - so its burning about 0,7 Liter/100km)
because the oil warning came on twice on the way home and she filled up.
That really says to my that the air i feeled wasn´t just "normal wear" :(
volrem
Post by volrem »
Probably it's cheaper to install new (used new) engine.
But I would still do some more measurements just because it's good case to study from.
I would like to see WPS on crankcase along with cylinder sync and crank sensor (engine running). And same thing but WPS in #2 cylinder (running compression).
terbo
Post by terbo »
Yes, thats the Plan - organized a used Engine today and started
ripping the old Engine out.Just a 1,4l - 2 Hours and its out...
I did some running Compressions before i started just for kicks
and because someone asked.Sorry, but now the Engine is out
besides 3 Bolts of the Engine Mounts....Everythings off already.
Maybe something usefull in the running compressions....
Greets
Chris
z4run2.psdata
Cylinder 4 Idle - lower Scale
(575.96 KiB) Downloaded 587 times
z4run1.psdata
Cylinder 4 Idle
(501.22 KiB) Downloaded 619 times
z3run.psdata
Cylinder 3 Idle
(500.74 KiB) Downloaded 625 times
z2run3.psdata
Cylinder 2 Idle - lower scale
(546.7 KiB) Downloaded 576 times
z2run1.psdata
Cylinder 2 Idle
(485.34 KiB) Downloaded 616 times
z1-run.psdata
Cylinder 1 Idle
(497.32 KiB) Downloaded 645 times
tode
Post by tode »
If the test with WPS sensor in the intake manifold has given negative results, the problem of your car is a relief valve damage, from Z2-1 file it is clear that the lack of exhaust bag because the pressure rises quickly, a test, confirming, my idea is a test with 500 WPS in the exhaust pipe.
Bad waveform, for me the exhaust valve doesn' t  close.
Good waveform
Good waveform
My wild stab is a problem with the inlet valve of #2.
Cylinder pressure goes way below inlet manifold. No air entering engine.
Nothing to compress, so low compression.
High cylinder vacuum drawing oil into the cylinder and pumping it out.
But Hey! Chuck an engine in.
HTH
