question for direct injection current waveform
eric989
Post by eric989 » Mon Mar 14, 2016 10:39 am
Hi all,
Can direct injection current waveform tell the time of pintle lifts off its seat? There is no obvious hump point on the current waveform like the injector located on inlet manifold.
The file I downloaded from waveform library. I can tell the injector closed time, Can somebody tell the start open time? Many thanks.
Eric
Audi_A3_柴油直喷.psdata
(619.47 KiB) Downloaded 139 times
LucaB
Re: question for direct injection current waveform
Post by LucaB » Tue Mar 15, 2016 6:41 am
Hi Eric.
From what I've always seen when the control voltages are high, it is difficult to see when the actuator opens
Luca
roadserpent
Post by roadserpent » Tue Mar 22, 2016 6:17 am
I may end up being corrected here by a pico master user or tech, but I believe that you may be working with a piezo type injector. If I am correct you should be using a 3rd channel to monitor the injector ground, and from what I have read and understand is that piezo or pizzio injectors work with ceramic discs that warp with voltage being applied in one direction and then when polarity is reversed the discs warp the other way. Thus creating the movement to work a pintle off a seat by means of some mechanical linkage. A pintle hump in a waveform is created when a iron core rod moves through the magnetic field of a coil of wire that has voltage applied to it. A piezo injector does not operate in this manner and will never show you a pintle hump in the waveform. Just my opinion from what I have read.
Post by STC » Wed Mar 23, 2016 6:33 am
and that "blip" coincides quite nicely with peak voltage
Post by STC » Wed Mar 23, 2016 9:23 pm
Post in Error
busjockey
Post by busjockey » Fri Mar 25, 2016 6:21 pm
What type of Vehicle is this?
