Math channel to control cylinder balancing, from alternator
LucaB
Post by LucaB » Sun Mar 13, 2016 10:29 pm
Hello to all.
I wanted to share with you the possibility to check the cylinder balancing the alternator ripple.
I tried to do some testing but the result is not good, at low speeds the frequanza is incorrect and falls.
I tried to create a sinusoidal signal of the alternator ripple.
When I want to find the math channel frequency that I created, the formula fails
Any suggestions on how to set the correct equation.
Thanks for your attention.
Luca
Ripple alternator.psdata
(3.63 MiB) Downloaded 124 times
victor2k
Re: Math channel to control cylinder balancing, from alterna
Post by victor2k » Sun Jul 17, 2016 1:12 pm
I think you must use filter for small ripple...or you must check the crankshaft signal for deceleration or acceleration.
Also the cylinder balance from Pico Diagnostics will not give the same results if you check for 3-4 times the same engine...too much noises must be filtered,the connection point is very important...
Post by STC » Mon Jul 18, 2016 10:03 am
Victor
Pico do have that test in the Pico Diagnostics Software although it works better on older cars and can flunk on later vehicles due to access, interference, smart charge etc.
I have found Cylinder balance is best achieved with a Math Channel riding on the CKP.
Airmass, Exhaust & Intake pulses can be viable alternatives. I guess it would be a case of what works best for you.
Post by Steve Smith » Tue Jul 19, 2016 3:06 pm
Hello and thank you for the post and the replies.
It great to see math channels getting such use as they reveal so much more detailed contained within the original capture.
For cylinder balance the crank sensor would be the preferred choice but that's not to say we cannot use the math channel on any signal like ALT Ripple or those mentioned above.
The ALT Ripple can be notoriously unstable regardless of engine condition and for this reason I tend to steer clear unless this is all you have to work with.
Lets face it, we have to work with what we have.
In the scenario above Luca, the frequency math channel is dropping due to the crossing point of the signal falling below the threshold. (See image below)
In this scenario, if you are happy with the output of the alternator (DC coupled) then switch the scope coupling to AC. Here we reject the DC and have the Ripple presented about zero volts.
This then makes for a stable crossing point on which to create an RPM math channel to evaluate cylinder balance.
