Glow plug current measurement
victor2k
Post by victor2k » Fri Feb 26, 2016 9:39 am
Last week I checked a Skoda Octavia III /CAYC engine type for glow plug fault code.
In Waweform Library Browser I can't find a good capture.
The singal was registered when the active test for glow plug relay was on.
I was used Pico 4425 and TA018(on 20A scale).
How I can add a good capture ?
Thank you.
t bujie3 cayc 1.6.psdata
(466.06 KiB) Downloaded 143 times
taho
Re: Glow plug current measurement
Post by taho » Sat Feb 27, 2016 10:28 am
This is also a good capture. Try also to use on the timeline - 1 s /div ( instead of 10 ms / div).
You should also check the remaining glow plug.
volrem
Post by volrem » Sat Feb 27, 2016 11:02 am
Instructions how to use waveform library and add capures can be found here: topic10063.html
