Uploading scope traces
Webbo
Post by Webbo » Wed Nov 18, 2015 4:52 pm
I have today saved an interesting trace and wanted to upload it to the forum, with internet connected, pico connected and forum logged in I tried several times.
You must be logged on to upload it says - what am I doing wrong ????
PicoPhil
Re: Uploading scope traces
Post by PicoPhil » Thu Dec 10, 2015 4:05 pm
Hi. On saving the waveform, did you fill in the vehicle information drop down menu boxes. There is a requirement to put make, model,year and fuel type in, otherwise it will not load the file.
Phil
PicoMike
Post by PicoMike » Tue Dec 15, 2015 12:13 pm
Webbo wrote:I have today saved an interesting trace and wanted to upload it to the forum, with internet connected, pico connected and forum logged in I tried several times.
Just to be clear, you must be logged in to the waveform library from within PicoScope. Although you use your forum credentials, these must be entered within PicoScope (whether you are actually logged in on picoauto.com/support is irrelevant).
If you choose File > Waveform Library Browser it will reveal the login screen. If you login (using forum credentials), close the Library browser then try saving the waveform again, that should work.
Hope that helps,
Mike Valentine
