Not communicate
T-by
Not communicate
Post by T-by »
Hi!
I had eight years ago a PicoScope 3423. Until now,was used a 32-bit Windows XP SP3 machine, and the software was running perfectly. Now, to be faster I replaced the computer to a 64-bit Windows 7 machine (4GB RAM, 3,2GHz processor, USB 2.0, USB 3.0). Unfortunately, the PicoScope 6 Automotive software 6.10.18 can not communicate with the device. :cry:
The Windows device manager found the Picoscope. What could be the problem? Isn't it compatible? What is the solution?
Thank you in advance their response:
T-by
Re: Not communicate
Post by Martyn »
With device manager open, if you start the software does the device disappear from the list ?
If so then this may be due to there being insufficient power provided to the device when it starts operating. What make of laptop are you using ?
If you are not using a blue Pico specification USB cable then please contact support@picotech.com referencing this post.
T-by
Re: Not communicate
Post by T-by »
Hi Martin!
Thanks for the quick response. The device manager does not disappear when the program starts.
Moreover, he writes that "Up according to the device is working."
This is not a laptop, but a new desktop computer.
Unfortunately, I  have not blue cable, but several other cable socially.
Thanks: T-by
T-by
Re: Not communicate
Post by T-by »
