Astra 2006 1.4 alternator ripple test
RoryMac
Post by RoryMac » Thu Sep 17, 2015 9:22 am
I hope someone could help me with this waveform. The ripples seem to be ok but I don't understand the 'flat spots' throughout the waveform. Is this a faulty diode or is this a normal condition?
Opel_Astra H Twintop_2006 Alternator test.psdata
(6.52 MiB) Downloaded 293 times
Re: Astra 2006 1.4 alternator ripple test
Post by Steve Smith » Mon Sep 21, 2015 11:26 am
Hello RoryMac and thank you for the post.
Would it be possible to take this capture again but over a longer time frame? (200ms/div)
Why I ask, yes I can see the flat spots but they seem very sporadic when moving through the waveform buffer, rather than repetitive (in a specific pattern)
The AC ripple itself looks fine can I ask, was the engine speed stable (idle) throughout the capture and do you know if any load was placed across the battery during the capture? (E.g. cooling fan)
Engine speed and battery loading will all effect AC ripple, as will SMART charging systems where charging is often cycled and present when necessary.
If possible on recapture could you monitor Battery DC, Battery AC, Charging Current and any Communication line (SMART charge control) at the alternator.
Here we could see if the flat spots relate to alternator output, battery load or activity on the communication line?
Take care......Steve
LucaB
Post by LucaB » Sun Oct 11, 2015 11:03 pm
Hello
To see well what happens in the alternator, you have to place clamp the output of B +
Best regards
Luca
