CAN signal decoding
LM358
Re: CAN signal decoding
Post by LM358 » Thu Sep 17, 2015 4:59 pm
Thanks for the info Steve !
So we have a kind of built-in acceptance filter in the Pico; I did not know that.
@ Belet: OBD2 communication is mostly between DiagTool and Engine ECU.
Therefore, it is best to search for the identifier 7E8 (= engine ECU - only valid forb OBD2, not for
internal communication with other ECU's).
Please do understand that OBD2 is query - reply based. The diag tool (scanner) wil send queries (ID = 7DF) and receives replies (ID = 7E8). You will see both ID's on the bus while reading the "live data".
Good luck - Eric (Flanders, part of Belgium)
Belet
Post by Belet » Fri Sep 18, 2015 8:41 am
Thanks for your sharing, Eric
I learned a lot about Can bus in depth.
You are an adept at it.
Best regards
Belet
