Sample waveform for Vauxhall Insignia Active ABS Current?
Re: Sample waveform for Vauxhall Insignia Active ABS Current
Postby brett nz » Thu Sep 10, 2015 1:03 am
I find the best way to see these small signals is by making a simple coil wrap with copper wire. Wrap copper wire 100x, solder a couple of terminals on ends and plug in to wiring to sensor. Then use 60A clamp around your 100x coil to read your signal which is now magnified 100x to make much easier to read.
Cheers
Brett
brett nz
Postby PicoPhil » Thu Sep 10, 2015 11:36 am
Just what i have done and it works well. :)
PicoPhil
Previous
