Renault Espace 4 Can Bus
AlanEss
Post by AlanEss » Sun Aug 02, 2015 12:55 pm
Hi everyone. I am completely new to all this. That probably explains why I bought a second hand 4424, because I didn't realise the 4425 was the dedicated auto scope.
However I can still use it though not with the auto software.
I am the owner of a Renault Espace 4 2.2 Dci turbo. I have just rebuilt the engine with new rings and shellls etc.
Using the Renault Can Clip software it reported that there was a problem communicating with some of the computers on the multiplex network.
having connected to the Can Bus with my scope. I have readings which are not mirror images of each other from the Can High and Can Low.
Can anyone point me in the right direction as to what is going on?
I will attempt to upload the readings from the scope, which were taken from the diagnostic socket.
espace 4 caan bus 1 no rcharge.psdata
(1.68 MiB) Downloaded 264 times
Re: Renault Espace 4 Can Bus
Post by Robski » Sun Aug 02, 2015 7:02 pm
WOW :shock: RCC, scope, cheaper taking it to a garage than buying that lot surely (guessing you're a DIY'r ?), what version RCC ?
That's what a scan tool/scope & tech info is for isn't it ?
Use an official WD & network topology & isolate controller's/wiring sections .............
NOTE : I have not looked at the file.
Post by Technician » Sun Aug 02, 2015 7:07 pm
The Network looks poor, I am assuming that you have checked the resistance of the Power Train BUS?
A reading of approximately 60 Ohms should be recorded.
Where any U Codes recorded?
Post by Robski » Sun Aug 02, 2015 7:44 pm
It might be an idea OP if you speculate what the problem is with the car ?
AlanEss
Post by AlanEss » Sat Aug 08, 2015 1:34 pm
Sorry everyone did not realise the scan results do not open on the forum.
I have checked the resistance it is62 ohms.
The trace is not a flat base line, but shows as a fuzzy baseline about 1/4 inch high. Not as it shonuld be, flat nd the signals are peaks and troughs not square waveforms as they are in one of the case studies
The can low red trace shows troughs that cut though the baseline signal.
That is as c!ear as I can describe it in words.
tode
Post by tode » Wed Aug 12, 2015 9:11 pm
The signal line can No problem is speculate and electrical levels are ok, to collect more reliable measurements on bus line serves a special probe that limits the noise due to the impedance of the input channels of Pico.
In cars Renault communication problems, they are due:
to internal failures of the control units that do not communicate;
or to a wrong configuration of the CAN, in dedicated units, such as UCH and Airbag.
Warning: if you use the original diagnosis (or similar !!!) you can rlevare communication failures do not really exist if the motor is turned off because of the CAN lines is awake, but do not generate type errors Uxxxx.
