RPM SIGNAL
JOE TECH
RPM SIGNAL
Post by JOE TECH » Wed Jul 29, 2015 9:05 pm
Hi can anybody help with rpm sensor signal for a citreon berlingo 2006 1.9 diesel engine code WJY
Previous attempt by other repairer had ecu checked new sensor fitted
The BSI will not come out of economy mode no lights or wipers without rpm signal engine fault rpm sensor
Had new clutch fitted recently suspect flywheel damage
I need correct signal to check theory
Thanks joe
PicoPhil
Re: RPM SIGNAL
Post by PicoPhil » Fri Sep 11, 2015 10:22 am
Hi Joe
Welcome to the forum group.
Have you looked on the waveform library for any information. Do you have a friendly Autologic garage who can help.
Philip
