Toyota hiace 2013 Air Cond cuts out
Postby tangoman » Mon Jul 20, 2015 12:12 am
This is can high can low on a 2012 Toyota came in to my work shop from a Toyota dealer they just fitted a new Air con comp and they had order a new ECU no ECU in the Australia new one coming from Japan the bill was up to $2500 and car still not fixed ? problem with car air cond cuts out after motor running for about a min cycle the key and it works again for a min no codes but at the same time the air cond cuts out scan tool will also lose communication .. ?? this one great for me to use my lab scope on to see if I can fix it did take me more then a hour but the fix ?? again no parts needed ?? someone had wire in a GPS tracker on the can high can low wires cut the wires and bingo air cond worked great now the customer wants there $2500 back from Toyota dealer
Re: Toyota hiace 2013 Air Cond cuts out
Postby PicoPhil » Fri Sep 11, 2015 12:54 pm
Thanks for this information on the Toyota Hiace. Great to share these problems and proves why PicoScope is such a great tool to use.
Thanks again for all your waveforms added onto the waveform library.
Return to Case studies
