VW TDI Pumpe-Düse with extended holding current
Post by KimAndersen » Thu Jul 16, 2015 8:14 pm
For those who likes diesel engines from Volkswagen which are equipped with a 2.0 Pumpe-Düse engine (engine code BMM) are here something that I would like to share with you.
As I´m a curious to know how things works and sometimes not, wanted I to find out the relationship between fuel temperature and the injection time on a VW Pumpe-Düse engine were.
This image is showing the electrical current ramp on pumpe duse injector number 2 together with a reference waveform in the background. As noted is there a difference between those waveforms, where the reference waveform have a slightly longer holding current - precisely 234 microseconds.
VW Pumpe Düse - extended holding current
The long holding current is something I made by putting a 330 ohm resistor inside the fuel temperature sensor (G81) connector and thereby simulating a fuel temperature in the return hose at 101 degrees celsius which of course is a very high fuel temperature compared with the normal reading at around 70 degrees celsius.
A question for you readers - is the longer holding current equal with a longer injection time and thereby more fuel is being injected into the engine.
I know, I could just have connected my VCDS tester and I would have the answer, but I forgot to make that test.
These are my thoughts whether or not this can be used in a diagnostic context will the time show, I just wanted to show that this can be seen in the electrical current ramp with a Picoscope.
VW_TDI_2.0_PD_CURRENT_RAMP_EXTENDED.psdata
(1.64 MiB) Downloaded 223 times
Kim :wink:
Re: VW TDI Pumpe-Düse with extended holding current
Post by Robski » Thu Jul 16, 2015 9:41 pm
did you take into account smooth running values ?
Post by KimAndersen » Fri Jul 17, 2015 3:05 pm
Robski wrote:did you take into account smooth running values ?
No, I didn't.
My theory or conclusion regarding the extended holding current may not be the whole true. Today
was I trying to replicate the same test as yesterday, but this time with a warm engine and this
time I couldn't extend the electrical holding current by the 330 ohm resistor in circuit.
The test today was conducted with a 5K ohm potentiometer in circuit with the fuel temperature
sensor (G81) and the objective with this test was to simulate different fuel temperature from as
low as 0 to 140 degrees celsius and at the same observe the holding current ramp.
This is not easy task with a potentiometer in circuit you can easily make to big adjustment and
hit the upper threshold at 140 degrees and when this happens, it slowly descends to the default
value at 40 degrees celsius and a DTC are present in memory together with some valuable freeze
frame data.
There is no doubt that it has a big influence on engine behaviour when you listen to it. A simulated high fuel temperature will make the engine run more smoothly or softer, but this is because it retards the injection point.
I believe that my observations with a cold engine still is true or at least to someone else have some more vital information regarding PD injector holding current and the fuel temperature.
Kim :wink:
clt
Post by clt » Wed Jul 22, 2015 12:13 pm
Hey Kim
I do not now if you can use this, but this is what seat writes about the fuel temperatur sensor.
SIGNAL APPLICATION
This signal is used by the control unit to
determine corrections in the volume of fuel to be
injected. To determine this value, it first makes
an internal calculation based on the sender
signal, in order to determine the fuel density.
The fuel density has an influence on the mass
of fuel being injected, since for the same
injection time, the lower the fuel density, the
lesser the fuel mass injected and vice versa.
Regards Claus
Post by KimAndersen » Thu Jul 23, 2015 11:00 am
Hi Claus
Thanks for the information but I already knew this.
The manufacturers in the automotive industry ain't that informative in telling about how the
calculations are done inside the ecu - I wonder why !!!.
One thing I know about the fuel temperature sensor (G81) which mainly are used in PD are that
it's used as substitute values for the coolant temperature sensor in terms of a fault or a diagnostic trouble code are present in the ECU memory and that goes the other way around too.
But, what I discovered when I was trying find some information about the fuel temperature sensor
(G81) is that the resistance table over the fuel temperature (G81) is identical with engine
coolant temperature sensor and that I didn't know before this investigation.
I´m not finished with my investigation of the fuel temperature sensor yet, so time will show
what I can find out about this sensor.
Kim :wink:
Post by KimAndersen » Thu Jul 27, 2017 8:54 pm
I'm back with some informations regarding the fuel temperature sensor G81 which are used in many VAG TDI cars equipped with a Pumpe duse engines.
This resistance/temperature map is only true, when used in combination with this G81 fuel temperature sensor with the following part number 038 906 081 B.
NTC - FUEL TEMPERATURE SENSOR G81.psprobe
G81 Fuel Temperature Sensor 038 906 081b
(2.23 KiB) Downloaded 176 times
This resistance map is more useful if the values are translated into voltage values and thats what I did. I´ve made a custom probe that cover the temperature range from 0 to 140 degrees celsius. The fuel temperature would´t get that high as 140 degrees celsius - when I did a road test it reached a temperaure at around 60-65 degrees celsius.
I´ve also made a simulated test with a 10 kohm potentiometer connected and at the same time hooked up to VCDS software just to verify that the custom probe are correctly made - which it was.
When you simulate a voltage value at around 100 degrees celsius - the upper threshold is reached and a substitute value of 40 degrees celsius are noted in the ECU followed by a diagnostic trouble code.
When I talk about substitute value are there someone who knows the substitute value that is used in the Bosch commonrail system !!!
Kim :wink:
Post by STC » Thu Jul 27, 2017 9:13 pm
Kim
Are you talking about Fuel Supply or Return Temperature Sensor ?
What value do you see in Data Blocks with Sensor Unplugged ? Is that your substitute value ?
Can you promote change to the substituted figure by manipulating ECT or other temperature sensors around the engine ?
Post by KimAndersen » Fri Jul 28, 2017 9:05 am
STC wrote:Are you talking about Fuel Supply or Return Temperature Sensor ?
I meant the fuel supply line in a bosch common rail system - what substitute value do they use !.
I do not have a engine in front of me with a common rail system right now - so it was out of curiosity - what are the differences between the two systems in terms of substitute values.
Kim
Post by STC » Fri Jul 28, 2017 2:05 pm
I have a VAG Common Rail at home I can look at? This thread is about PD ?
victor2k
Post by victor2k » Sat Jul 29, 2017 7:26 am
Kim :wink:
When your fuel temperature sensor signal is improbable Ecu will use the engine temparature value.
If both sensor will fail then will be used a substitute value for a cold engine(is not specified a value of temperature).
According to ESI this will be available for both systems(PD with EDC16 and common rail with EDC17.Don't know how will work PPD...).
Regards.
