10:1 attenuator
10:1 attenuator
Postby johan verdeyen » Mon Jun 08, 2015 1:13 pm
He guys
Do you always use a 10:1 attenuator for measurements on a primary ignitioncoil?
johan
johan verdeyen
Re: 10:1 attenuator
Postby roadserpent » Mon Jun 08, 2015 7:11 pm
The older 4423 and 4223 automotive Pico scopes had a max input voltage of 100 and utilize a 20:1 attenuator. The newer 4425 and 4225 scopes have a higher input voltage limit, and come with and would use the 10:1 attenuator.
roadserpent
Re: 10:1 attenuator
Postby hijakd » Sun Jul 12, 2015 1:18 pm
Hi I alway s use a 20:1 att on primary ignition and injectors,I have seen anywhere from 100-400v on the primary and 60-110v on an injector
hijakd
Re: 10:1 attenuator
Postby PhilS » Fri Sep 11, 2015 2:29 pm
you can use either the 10:1or 20:1 attenuators. Remember to watch out for that when using downloaded reference waveforms or Guided Tests from within the software. If they were saved using a 20:1 and your signal is connected through a 10:1 then remember to adjust scaling, mentally or in PicoScope, if you want both with the same visible amplitude.
PhilS
