WPS600
Re: WPS600
anything that's constantly monitoring pressure as opposed to just testing it
Re: WPS600
That a pretty wide statement say I've got a intermittent faulty that only occurs very intermittent like every two hours is this testing or continuous operation ?
What I'm after is something a little more specific ie: at 8000psi a 1 min test period is acceptable.
Re: WPS600
The WPS600 is intended for diagnostics but not permanent mounting / use.
The battery life between charges is a few hours so its fine to leave it connected until the battery goes flat.
Re: WPS600
Thanks Alan
