fiat seicento engine change
Postby bambi29 » Tue May 12, 2015 10:23 pm
Hi all
New to the forum so hello
I have a fiat seicento that I use for work .it used to run with the original 1108 engine in it but every so often it would hesitate any way two weeks ago the engine failed it had done 196,000, so I decided to fit a later model punto engine in it 1242cc everything was fairly easy I had to change a few things but in three hours it was in and running but!.it has no go in it at all and now drinks fuel iv tried a new crank sensor ,cam sensor , injectors,col packs ,plugs,leads,maf sensor,iap sensor also tested tps .i have also scoped the crank and cam sensor .used g scan to read live data and flight record whilst driving everything seems to check out ok any ideas any help would be most appreciated I'm at the end of my tether
Re: fiat seicento engine change
Postby PicoPhil » Mon Sep 14, 2015 5:03 pm
All i can say is good luck and we all learn by experiences. Check all the sensors and systems are the same. Hope you have the wiring diagram.
Good luck.
Return to Help me fix my car
