2009 insignia cam fault
Sam-F
Post by Sam-F » Mon Apr 27, 2015 2:10 pm
I have a 2009 Vauxhall Insignia 1.8 2HO/A18XER petrol that has just been brought in from another garage who have fitted a replacement engine to it. But the car is idling & running rough & turns over for about 10 to 15 seconds before it starts .
on scanning I get P0341 inlet cam fault and P0366 exhaust cam fault
I have scoped the 2 cams attached (001psdata)
And the crank and a exhaust cam attached (002psdata)
but I don't have any scopes images to compare them too can anyone tell if the timing is correct these scope images
thanks Sam
Vauxhall_Insignia_2009_Petrol_20150427-0001.psdata
(3.81 MiB) Downloaded 428 times
Vauxhall_Insignia_2009_Petrol_20150427-0002.psdata
(4.68 MiB) Downloaded 265 times
PicoPhil
Re: 2009 insignia cam fault
Post by PicoPhil » Fri Sep 11, 2015 1:15 pm
Hi Sam
Thanks for your request on the forum about your problem vehicle. Please remember that you can always look on the waveform library for examples of camshaft sensor waveforms. We have just been involved with nice VW Polo 3 cylinder engine problem. A case study will follow but the chain had slipped 5 teeth and found with the WPS 500.
We always welcome saved waveform on the library, even if they are faulty sensors.
Philip
insignia15
Post by insignia15 » Thu Oct 20, 2016 9:31 pm
Hi Sam. Have you sorted the problem with camshaft faults after fitting a replacement engine? I've got the same issue. Can you please give us some advice. Thanks in advance.
