WPS 500 charging
Liteace
WPS 500 charging
Post by Liteace » Thu Apr 23, 2015 10:13 am
Couple of questions
Whats the run time of WPS with fully charged battery and when is it fully charged, in the manual it says:
Charging indicator:
Lights up when
battery is charging
Does the light go out when its fully charged, on mine the red LED will light bright to start then glow dim after a couple of hours but it never goes out out, in this pic you can see the LED glowing but it making it look brighter than it is, I have to shield it from any light to see the LED glowing dim
If I do leave it charging all night like I do with me phone and laptop will it overcharge and damage the battery ??
PicoChris
Re: WPS 500 charging
Post by PicoChris » Fri Apr 24, 2015 8:16 am
Hi there
the charging circuit in the WPS500 is safe to be left on over night but to get the best out of the battery I would not keep it on charge continually.
The battery should take around 4 hours to charge fully from flat but for the best result I would recomend discharging the battery before recharging.
