WPS500 IN RADIATOR
lavoie
WPS500 IN RADIATOR
Post by lavoie » Wed Apr 15, 2015 12:24 am
Can i connect my wps500 transducer or FLS to radiator to check and identify a bad cylinder headgasket?
No problem with the hot coolant?
If possible , do you have any picture of your connection to radiator
thanks
Re: WPS500 IN RADIATOR
Post by Robski » Wed Apr 15, 2015 9:01 am
yes, but I wouldn't use the FLS for fear of water ingress !
lavoie
Post by lavoie » Wed Apr 15, 2015 11:37 am
Thanks to reply
what's the procedure to do?
I must must remove antifreeze,engine cranking,engine running,remove the belt(water pump)?
thanks
