60MHZ probe
Bubeh
60MHZ probe
Post by Bubeh » Sat Apr 11, 2015 4:16 am
Which among the inputs/outputs can the M1007 60 MHZ probe be use?
Re: 60MHZ probe
Post by Fat Freddy » Sat Apr 11, 2015 10:27 am
HTH
Bubeh
Re: 60MHZ probe
Post by Bubeh » Sat Apr 11, 2015 4:23 pm
ok thanks...i'll try it with my injectors n sensors.
Pontisteve
Re: 60MHZ probe
Post by Pontisteve » Wed Feb 15, 2017 8:08 am
Could somebody clarify for me exactly what the M1007 60 Mhz probe is for?
If it's for injector testing, I've just been using my 20:1 attenuators to prevent scope damage.
PicoKev
Re: 60MHZ probe
Post by PicoKev » Wed Feb 15, 2017 10:38 am
Direct copy and paste from the Pico Product Website:
:arrow: This high-quality general purpose oscilloscope probe has a 60 MHz bandwidth. A two-position slide switch allows attenuation of either x1 or x10 to be selected.
This probe is particularly useful if you want to probe CAN bus and FlexRay signals.
Pontisteve
Re: 60MHZ probe
Post by Pontisteve » Wed Feb 15, 2017 11:36 am
So it's a 10:1 attenuator. With some sort of fine tuning screw. Is this just a lead with a quick method of adding 10:1 attenuation?
Re: 60MHZ probe
Post by Autonerdz » Wed Feb 15, 2017 5:15 pm
Pontisteve wrote:So it's a 10:1 attenuator. With some sort of fine tuning screw. Is this just a lead with a quick method of adding 10:1 attenuation?
Unless you are looking at Flex Ray, you don't need to use it. Flex Ray signals can exceed the bandwidth limit of the standard test leads so then you need the 60MHz probe. Standard test leads are fine with CAN.
andrewbishop66
Re: 60MHZ probe
Post by andrewbishop66 » Thu Feb 16, 2017 10:41 pm
standard oscilloscope probe with a bandwidth of 60mhz
on a standard scope ie electronics field they have a square wave output the tuning screw is used to correct the sample waveform to a perfectly square waveform on screen for correct calibration
also available in various bandwidths and higher attenuation ie 1:100
Thanks Andrew
