1997 Plymouth Breeze SOHC Stall/ no start P0351
redclift38
Post by redclift38 »
Plymouth_Breeze_1997_Petrol_20150220-0001.psdata
(561.34 KiB) Downloaded 719 times
This is an intermittent no start and stall when it gets warm. Tried wiggling the ignition wires and scoped the cam and crank as seen in the attachments. Before I used the scope, the test light( connected to the ignition + power source)went out when it stalled. As far as i know, the ignition pwr comes from the ASD Relay. Now, I cant get it to stall after running for 2+hrs but it is 10degrees outside. Attached is the primary and Coil Amp Ramp. At the top, there is an odd dogleg that I have never seen.
sigoaprendiendo
Re: 1997 Plymouth Breeze SOHC Stall/ no start P0351
Post by sigoaprendiendo »
redclift38 wrote:At the top, there is an odd dogleg that I have never seen.
Hi redclift38
I haven't ever seen this dogleg at the top before, looks like a coil internal winding in short and the coil driver struggling to cope with such a high current values. Check specs for this particular coil and we'll see. Maybe 7 amps is too much, just compare with another coil pack to be sure.
