misfire detection by engine speed signal.
As misfire detection is done by the ecu by monitoring the fluctuations of the engine speed sensor, is it possible to monitor this signal varation yourself using a picoscope?
Re: misfire detection by engine speed signal.
Why don't you do a search of the forum for RPM math from the CKP sensorheady2010 wrote:As misfire detection is done by the ecu by monitoring the fluctuations of the engine speed sensor, is it possible to monitor this signal varation yourself using a picoscope?
It would be possible to do this, but you would need other metrics, You could measure rotation over time and compare the signal peaks from the ckp to determine that a misfire occurred but it would be time consuming to figure it out. Also you wouldn't know why the misfire occurred. You would also want ignition wave and/or o2 data to support your findings and identify fuel status during the miss. in stead you could use the cylinder balance test in pico diagnostics, or (BETTER) you could scope the ignition. much faster that way, tells you fuel status, plus you can trigger the number 1 cylinder and used the firing order to locate the miss.
- Fat Freddy
- TwoWaves
Grass hopper.As misfire detection is done by the ecu by monitoring the fluctuations of the engine speed sensor, is it possible to monitor this signal varation yourself using a picoscope?
As Robski says, search and ye shall find. I know this has been covered many times. Steve has done a great deal on this as well as Robski, myself and others. But to answer your actual question. - Yes, it is possible.
HTH
Fat Freddy.
Ok thanks for the information. My thinking behind this was that I have heard of cases where the crank bearings have worn (without creating excessive knock) causing a fluctuation in the engine speed signal and then making the ecu think there is a misfire, I'm thinking this wouldn't show up on an ignition wave form or a in cylinder preasure transducer?
- Autonerdz
- TwoWaves
- Contact:
You might find this case interesting:heady2010 wrote:Ok thanks for the information. My thinking behind this was that I have heard of cases where the crank bearings have worn (without creating excessive knock) causing a fluctuation in the engine speed signal and then making the ecu think there is a misfire, I'm thinking this wouldn't show up on an ignition wave form or a in cylinder preasure transducer?
http://www.picoauto.com/support/topic93 ... ?hilit=bmw
Some digital oscilloscopes have such soft.They are very useful because they help to identify difficult cases in the diagnosis of the mechanics of the engine, when the normal gauge or pneumotest useless or difficult to use.
