I'm very new to using pressure transducers and only have a snapon 500psi version but I have bought a 12v to 5 v convertor so it can be used with my picoscope (to a point) but is there any way I can setup the transducer to read psi rather than the voltage over time scales if I know the voltage/psi output.
I realise it maynot be to accurate but as a comparison access all cylinders it maybe acceptable. Is the actual presure reading that important or more the waveform detail for diagnostic use. A compression gauge can give us an actual figure.
thanks
lee
