Engine mechanical test
Cerciz
Post by Cerciz » Fri Jan 09, 2015 1:38 pm
any help with in cylinder pressure transducer on common rail with piezo injectors(crank and run)on any car?
PicoMike
Re: Engine mechanical test
Post by PicoMike » Tue Feb 03, 2015 9:46 am
Cerciz wrote:any help with in cylinder pressure transducer on common rail with piezo injectors(crank and run)on any car?
Hi There,
Can you give a clearer idea of what you are after? Have you checked our preset tests within the software?
There may also be some of what you are after within the Waveform Library?
Mike Valentine
Cerciz
Post by Cerciz » Tue Feb 17, 2015 12:32 pm
Hello
Maybe i was not so clear,sorry for my english
Can we use pressure transducer to test compression,on running diesel engine with piezo injectors ,in a way that we do not cause those injectors get stuck(plug -unplug) or cause any damage to engine.
I want to know the procedure if any
No problem with the test on petrol engines or diesel
My concern are piezo injectors,making them stuck or damage during the test(engine runing)
vasek
Post by vasek » Thu Feb 19, 2015 10:50 am
It is possible to make adapters under glow plugs .In this case, the applied pressure transducers refrigerant from A/C MB :
hbr
Post by hbr » Mon Jun 15, 2015 6:17 pm
Do you have captured waveforms with this diy ac pressure sensor setup?
volrem
Post by volrem » Fri Jun 19, 2015 6:35 pm
vasek wrote:It is possible to make adapters under glow plugs .In this case, the applied pressure transducers refrigerant from A/C MB :
Hi vasek
What is pressure range for these A/C sensors? And do you have any waveforms to show?
vasek
Post by vasek » Mon Jun 29, 2015 1:12 am
Sorry for my english.Most of all A/C sensors have range like this (1) ,all of them have liner and thermostability characteristic .
So,- on diesel engine, they will fit only on cranking or compression test.On gasoline engine they will work on crankig ,idling and even part load in working cylinder .For example in Honda Fit, pressure sensor-instead of second spark plug cyl1(2).
You can use it for sync cheсk as much(3).
In some case, with extension, they will work on idling with diesel(4).
But the latest sensors work on digital base(lin technology) and they will not fit.
For diesel ,best results will be with fuel pressure sensors from GDI or CGI system.Also you can apply sensors from ABS modulator or CDI rail,but without the necessary precision.
(7.25 KiB) Downloaded 96 times
