question current ramp
rburgy
Post by rburgy »
CAN ANYONE TELL ME WHY MY CURRENT RAMP LOOKS ROUNDED LIKE THIS?
I AM USING A SNAP ON LOW CURRENT CLAMP-USING PICO SETTINGS. THE CURRENT RAMP LOOKS FINE
WHY I CHECK IGNITION CURRENT BUT CHECKING INJECTORS, ITS USUALLY ROUNDED LIKE THIS.
ANY HELP WOULD BE APPRECIATED. I AM UNABLE TO UPLOAD FILE BECAUSE I THINK ITS TOO BIG, PLUS I ALREADY UPLOADED TO WAVEFORM LIBRARY. YOU CAN SEE IT IN THE LIBRARY
2004 TOYOTA CAMRY-rburgy is my UN
THANKS GUYS/GALS
Toyota_Camry_2004 SHARE CURRENT.psdata
(2.52 MiB) Downloaded 609 times
volrem
Re: question current ramp
Post by volrem »
You have too agressive fiter on channel B (313Hz). Remove filter or raise filter frequency.
Also your voltage level goes beyond 100V so you need to increase scaling.
Toyota_Camry_2004_Petrol_20141228-0001-unifiltered.psdata
Filter removed
(870.08 KiB) Downloaded 577 times
rburgy
Post by rburgy »
THATS AN EASY FIX. THANK YOU. I FIGURED IT HAD TO BE SOME KIND OF SETTING. I HAVE A BAD HABIT OF USING FILTERS TO OFTEN TO GET RID OF NOISE.
