Battery test, wrong symbols
LucaB
Post by LucaB »
Usually try to use efficiency battery tester special.
I wanted to try to test pico diagnostics but in my opinion you should correct stamps.
Battery EN 800A can not be good.
With internal resistance by 7.47mohm had to be put red dot
Internal resistance of a battery 800A EN must be less than 4.7mohm.
Best regards Luca
Re: Battery test, wrong symbols
Hello Luca and thank you for the feedback.
Can I ask if you carried out the same test after the battery was recharged?
It would be interesting to note the internal resistance value after recharging has been carried out.
Do you have a specification chart confirming the value 7.47 mohm is incorrect for 800 EN rated battery (Lead Acid)?
Do you have an alternative test method for the battery under test for a comparison? (AC conductance test)
Sorry for all the questions as this will help to investigate the values obtained during the Pico battery test
Take care......Steve
LucaB
Post by LucaB »
Hi Steve
Before the test battery was charged.
Usually use digital tester for batteries
Table on the edge of the internal resistance battery in relation to their capacity, is inside my Motor tester.
Sa to tea does not mind the next time I happen battery no good, I can insert motortester test, and test with pico, to see differences
Best Regards Luca
Hi Luca, thanks for the feedback.
That would be great if you don't mind comparing the two tests on the same battery and displaying the results with the table for internal resistance values.
Sorry Luca I assumed the battery was not fully charged from the results obtained. "Good but recharge"
It would appear then that the result claimed the battery required charging when not necessary?
Can I ask if you had the latest software for this test?
Thanks again for the valued feedback and I look forward to the comparison results
Take care.......Steve
LucaB
Post by LucaB »
Hi Steve
Battery was charged
The software was updated as of the moment in November 2014
I'll put the two tests for comparison but the table of internal resistance batteries is copyright
Regards Luca
LucaB
Post by LucaB »
Hi Steve
Today had this car in workshop with battery no good
Test pico:
test motortester
Test with pico marks internal resistance good
Test with motortester marks battery no good
Actually no good battery
