toyota P0352 trouble code
evanlip
Post by evanlip » Thu Dec 25, 2014 9:53 am
i am dealing with a ignition coil of toyota previa 2.4L engine,
the owner complaint about the sudden misfire when the MIL light on,but after a while he drove,the MIL light goes off and the car runs like normal.
i plugged in my scan tool and the history code shows P0352 ignition coil "b" primary/secondary circuit.
so i checked them with the picoscope,channel one = control circuit,channel 2 = amp probe on ground,
the result that it shows just nice,a slight oscilation at the beginning than a nice ramp.
is this amperage graph enough to tell me that this coil is good?
or do i need to look at the IGF feedback signal as well?
coz i went out for a few rounds of test drive,and the car just nice.
LucaB
Re: toyota P0352 trouble code
Post by LucaB » Fri Dec 26, 2014 10:57 pm
Hi.
Charge psdata file.
Then we look together
Best regards
evanlip
Post by evanlip » Mon Dec 29, 2014 10:11 am
HERE IS THE CAPTURE,SORRY JUST A VIEW.
PLEASE CORRECT ME IF I NEED A BETTER SETTINGS.
acr50 coil 2.psdata
IGNITION COIL CURRENT AND TRIGGER SIGNAL
(408.37 KiB) Downloaded 285 times
tode
Post by tode » Sun Jan 04, 2015 11:06 am
You have rightly entered, the command by the engine control unit, the current consumption, but lacks the voltage signal of the primary, to better understand acquisizione with would need a longer time and at least one strong Expedited, then zoom in on the signal are controlled by signals .
Greetings
LucaB
Post by LucaB » Tue Jan 06, 2015 8:47 am
Hi Evanlip
Excuse my late reply.
I'd capture of the secondary circuit, if this is not available, remove ignition coil and add a cable candles maybe not resistive.
If ignition coil fitted with a response signal to ECM, you also capture him, this should be the signal that ECM determines the P0352.
As the saying tode, I would catch with longer times maybe 20ms / div but you have to increase the number of samples to screen (1MS) otherwise not see good peak power
tode wrote:You have rightly entered, the command by the engine control unit, the current consumption, but lacks the voltage signal of the primary, to better understand acquisizionecon would need a longer time and at least one strong Expedited, then zoom in on the signal are controlled by signals .
Greetings
Hi Tode
I think if ECM controls charging coil signal of about 4V, you can not take the primary signal.
Best regards Luca
evanlip
Post by evanlip » Tue Jan 06, 2015 5:11 pm
noted.lucaB and tode...thanks for the valuable sharing...will try again then.
