compression testing
compression testing
Postby fairway » Fri Sep 26, 2014 1:19 pm
hi there,
I'm hoping someone can help me,i can't remember how to do a compression test using the pico,can some one tell me how to do it?? thanks john
Re: compression testing
Postby arjen » Fri Sep 26, 2014 6:32 pm
You can open pico diagnostics and select compression test. Press F1 for info about the test.
You can also meassure the starter current or battery voltage during cranking to check if each cilinder takes the same battery power.
Return to PicoDiagnostics software
